I'm capturing HDTV RF signal to AVI using Ledteck 2000 expert card. I have to choose "uncompressed AVI" because my PC is slow and I can not compress is to straight DVD.
I always end up with AVI that has something like 300x200 resolution, i.e. when I view this AVI with Media player it is about that size. It is always 300x200 even if I'm capturing a VHS tape (via RF as well)
Now the question - how can I make my Ledtak card to record to an AVI with a higher resolution? Why the resolution is actually 300x200? Why the quality of an input signal is not taken into account when capturing?
try Virtual VCR and record to HuffYUV or any Mjpeg codec, then encode it to MPEG2 DVD.
no need big cpu, just big hard disk, and u'll be able to capture 720x480x29.97
Trying to better the quality of VOB file to a better resolution etc.
By LegendaryGamer in forum RestorationReplies: 3Last Post: 22nd Mar 2010, 17:09 -
How much does resolution affect file size?
By milkydoo in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 18:29 -
Bigger file with lower resolution after conversion???
By unplug in forum EditingReplies: 6Last Post: 20th Aug 2008, 17:09 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 07:49 -
Determining the resolution of a video file
By socool135 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jan 2008, 19:52
