I was recently having problems encoding an XVID with TMPGEnc. Once I set the DirectShow filter to 2, it worked, but TMPGEnc would say that the video was 30 fps when I knew that it was 23.976. In fact, I would see 58,000 something frames with VirtualDub, but when when I increased the directshow filter, I saw 70,000 something frames, so I wanted to fix it somehow that TMPGEnc would read it properly and encode properly. I think I installed some program called ffdshow or something like that. Ever since, even the same DIVX videos that I never had a problem with would crash half way into the 2-Pass VBR. I tried to uninstall and then reinstall DIVX & XVID. They still work when I play them in my media player, but they don't work in TMPGEnc anymore. I've also had VirtualDub check all these videos for errors, but VirtualDub found none. Even if I can't fix my problem with the XVID videos, is there any way that I can fix it with my DIVX videos, so they work like they used to. Now, when I do CBR, it gives me an "Invalid Pointer Operation" error at the very end, but it still produces a working MPEG2. The problem seems only to be in the 2nd pass of the 2-Pass VBR. I've encoded trial runs of these same exact DIVX files that I am trying to do now, and it never gave me a problem with 2-Pass even with the Motion Search Precision set at the highest setting. It only happened after I installed url=https://www.videohelp.com/tools?tool=168#comments]ffdshow[/url]. Now, neither DIVX nor XVID work with a 2-pass in TMPGEnc Plus. I've tried to uninstall and then reinstall DIVX, XVID, and evenTMPGEnc Plus down to the last registry setting - whatever I know to be related to the three - but it still does not work. I always get an "Illegal Floating Decimal Point Calculation Order" error. What is going on?
The problem seems to only be in the Divx 5.1.1 Codec and the Xvid Codec. Divx Mpeg4 Fast Motion & Divx Mpeg4 Low Motion seem to be encoded fine. Why is it that only the Divx 5.1.1 & Xvid codecs are not encoded properly? What's wrong? What can I do to fix it?
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 16:59 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 07:59 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 21:48 -
Removing subtitles, running 1st pass again?
By moviebuff2 in forum Newbie / General discussionsReplies: 1Last Post: 28th Dec 2007, 07:20 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 12:16
