I'm trying to convert an avi with ac3 sound using CCE SP and AVISynth, but every time I add the avs script to CCE, my file has always 240 frames and 10 seconds of duration.
I opened the avs script with windows media player and get the following error :
"ACM failed to suggest a compatible PCM format."
I can play the avi using Windows Media Player without the avs script, so probably I have the ac3 codec.
What am I doing wrong ?
AviSynth presents uncompressed video AND audio to any encoder or player. Therefore, by playing the avs file , the audio is NOT ac3 at that time, whereas the original avi audio is.
To overcome this you need to install the AC3 acm decompressor which will then process the avs audio by downmixing it to 2 channel stereo. If you want to keep the 5.1 ac3 you will need to demux (Virtualdubmod) it from the avi and multiplex it back in at the DVD author stage (assuming that's what you want to do).
How to burn avi file with true 5.1 ac3 sound on dvd?
By namesake in forum Video ConversionReplies: 17Last Post: 20th Mar 2009, 10:49 -
preserving 6 channel ac3 sound while converting from mkv to avi
By indianpunk in forum Newbie / General discussionsReplies: 4Last Post: 20th May 2008, 16:57 -
mencoder, convert mkv to avi + ac3. sound issues
By clavain in forum Video ConversionReplies: 1Last Post: 29th Jan 2008, 17:02 -
AVI with AC3 - No Sound
By Degradation in forum AudioReplies: 0Last Post: 19th Dec 2007, 16:28 -
Extract sound from AVI video and convert to AC3
By blizzery in forum AudioReplies: 2Last Post: 25th Jul 2007, 14:06
