I was recently looking at the back of my VCR and Laserdisc players. They both have a plug called "Remote." I know that you connect some type of headphone like jack to it. Is there a device that controls external devices through here? Perhaps a PC connection?
Also is there some IR control that can be used to control all home theater components through a HTPC? I really hated having to use 6 remotes to control everything.
You might do some research on X10 type equipment but if the issue really is the 6 remotes you can solve that a number of ways.
I use a Home Theater Master MX-700 remote that can be programmed on the PC and then downloaded to the remote. The Philips Pronto line of remotes also does that. Here's a link to THE site on remote controls.
http://www.remotecentral.com/
Home Theater
By Al27 in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2011, 17:37 -
WDTVLive VS Home Theater+ ???
By boofus in forum Media Center PC / MediaCentersReplies: 6Last Post: 30th Mar 2010, 00:15 -
Home Theater Projectors
By Lucifers_Ghost in forum Off topicReplies: 17Last Post: 18th Sep 2008, 01:36 -
all in one home theater systems
By CODEWERKX in forum Newbie / General discussionsReplies: 1Last Post: 4th Dec 2007, 11:09 -
Is your home theater organized?
By yoda313 in forum PollsReplies: 19Last Post: 28th Sep 2007, 07:21
