Some movies are under 4.7 gig, so a straight rip using DVD Decrypter and Nero to reburn seems a good way to make a backup.
However, a lot of movies that aren't excessively long still show 7-8 gig when you open them in DVD Decrypter. Why? Is this because there is both widescreen and fullscreen versions on the same disc? Is it possible to rip the movie onto a 4.7 gig disc (by disabling or removing one of the two versions)?
I've heard DVD Shrink is the best way to treat movies that are larger than 4.7 gig. Does Shrink separate the files into two discs or does it compress all the files to fit on a single disc? Is Shrink able to remove the widescreen version, thus creating a movie that will fit on a 4.7 gig DVD-R?
If using DVD Decrypter in ISO mode (Read), will it create an iso that requires two discs to fully burn or create an iso that needs a 9 gig DVD to complete?
If using DVD Decrypter to rip the disc to HD, then next using DVD Shrink, which setting on DVD Decrypter should be used? (File, IFO, or ISO)?
Your help is appreciated.
Steve
Results 1 to 12 of 12
Steve B
Humboldt, TN -
go find some shrink guides, it will give some answers,
btw look up dvd5 and dvd9g_i_l_s_t_e_r
Just the product of a society that's lost it's good manneres -
can i copy my netflix dvd to cd without encoding. I figure since 700 is bigger than 4.7, i should be able to put almost 200 dvds on a cd
Muahahahahahahahaha....Originally Posted by dj SOB
Get a clue and read a little...
makntraks. -
like the sarcasmOriginally Posted by ricky1756
shame about the math! its just shy of 150
MPG movies show shorter time then actual... help needed
By wolf_ast in forum ComputerReplies: 5Last Post: 30th Mar 2011, 21:52 -
25 gig BluRay to BD-R?
By Mark_Venture in forum Blu-ray RippingReplies: 3Last Post: 6th Sep 2009, 08:56 -
Trying to create a process for creating home movies reliably and need help
By Arphahat in forum Newbie / General discussionsReplies: 1Last Post: 16th Feb 2009, 12:19 -
How do you organize your movies and tv show collections?
By yoda313 in forum PollsReplies: 50Last Post: 10th Oct 2008, 20:36 -
How many 4.7 Gig DVDs may fit into 500 gig HDD?
By Bronx in forum ComputerReplies: 11Last Post: 24th Apr 2008, 10:40
