MAN I CANT BELIVE THIS..... I HEARD GOOD THINGS ABOUT THE SOFTWARE AND WASTED ALL THIS TIME GETTING IT..... THEN WHEN I GET IT .... THE DAM THING WONT IMPORT NONE OF MY MPEG 2 VIDEOS INTO IT FOR EDITING AFTER LEARNING HOW TO USE A LOT OF ITS FUNCTIONS USING A .AVI FILE!!!!!!!!! I NO THIS THING HAS TO TAKE MPEG 2 VIDEO..... WHO DA HELL WOULD MAKE A $100 PIECE OF SOFTWARE THAT CANT EDIT MPEG 2 VIDEO........... OH YEA..... SONY WOULD...... GARBAGE AZZ COMPANY![]()
Results 1 to 9 of 9
There is a free trial to download - didn't you do this first?
Regards,
Rob -
Are you sure about that? I am sure I did it with the trial version. I know it can create mpg2 videos. I would have to check in to that myself cause I was thinking of adding it to my collection of editing tools.
BTW, screaming at everyone in this forum is not the best way to motivate people to help.
dun4 -
and thats the thing.... it lets u turn your format into dvd (mpeg2) but it dont edited it...... i tried all my mpeg2 formats that i captured and it wont do anything.......i no theres nothing wrong with my captures because adobe pro pics it up......
STFU........Originally Posted by mol3000
Drop the caps lock and by the way - Try a DAMN spell checker before you post... DAM is spelled DAMN... Also how did you waste time leeching this software? Oh I know - downloads at 28.8 are teh suck........
Get a clue....
Too bad I've got real work to do....
makntraks -
From the Screenblast Support site.
Either you don't have the mpeg plug-in or it has expired. Contact Sony for the plug-in - proof of purchase is needed.Question
Can I use MPEG-2 files as a source format and edit them?
Answer
Yes, but this is not ideal. MPEG-2 files are heavily compressed, and when re-encoded, quality decreases significantly. Whenever possible, use Video for Windows (.AVI) or QuickTime source material of the highest possible quality.
Learn to do some research about your software before mouthing off about what it can't do - it just shows what you can't do.Regards,
Rob -
The mpeg file needs to be a program stream, not an elementary stream.
thanks disturbed1 but what is the difference ????? i got my mpeg 2 caps from my dc200
vegas movie studio
By pgo in forum Video Streaming DownloadingReplies: 1Last Post: 7th Jan 2010, 18:06 -
Will Vegas Movie Studio 9 do it?
By ccm in forum Newbie / General discussionsReplies: 2Last Post: 3rd Aug 2009, 13:41 -
Help Sony movie studio 8
By helper in forum EditingReplies: 3Last Post: 3rd Mar 2009, 00:10 -
Sony Vegas Movie Studio/DVD Architect Studio
By DJL82 in forum EditingReplies: 8Last Post: 1st Feb 2008, 15:14 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 18:53
