Is there a way to get around the 4gb avi limit on a fat32 drive using VirtualDub?
Results 1 to 9 of 9
yes and no.
No-you cannot get a single avi file to excede 2 gigabytes.
yes-some programs will split the capture file every 2 gigabytes.
4GB is a limit for non-avi files.
<font size=-1>[ This Message was edited by: Greg12 on 2001-11-03 18:17:32 ]</font> -
I can make an AVI up to 3.99gb then I get the message that an AVI can't excede 4gb on a fat32 drive. From what I understand the limits are 2gb for fat16 4gb for fat32 I'm not sure about NTFS but I know its huge. Converting to NTFS might be an option because I am using XP pro. But I thought I saw in a previos post that there was a way to get around it using VDub. I played with it but a can't seem to find any seamless capture option or anything like that.
http://www.vcdhelp.com/faq.htm#spillsystem
You can use AVI_IO too (some people get less dropped frames with AVI_IO vs. VDub) but it's limited to 3 files unless you register the program. I just use VDub -
Dayv,
Although the FILESIZE limit in FAT32 is 4GB, there is still a legacy 2 GB limit on AVI files (even if you are using NTFS). It depends on the program you are working on. Some programs will not open an AVI file larger than 2 GB (e.g., Adobe Premiere 5.x).
As for VDub, read the readme files and search the web again. You can use the spill system to do seamless captures over a number of files.
Regards.
Michael Tam
w: Morsels of Evidence -
Try this here. I think this is what you are looking for. It worked for me.
Thanks Boxingjunkie -
Go buy a hardware encoder for $199 and you can capture an entire movie in MPEG2 SVCD in less than 2GB, if you can afford XP Pro then a hardware card should be no problem.
No I can't really afford the hardware encoder. XP pro was free from microsoft. Its one of the only perks for being in computer sales. What I was trying to do is capture at a higher resolution. My capture card doesn't do a very good job at the higher resolution any way so I'm not to concerned. What I can do works good enough for now. I probaly wount be satisfied until I get DVD quality out of a VCD or until I get a DVD burner. I could win the loto
How to make AVI file to 1.4GB ?
By zovx in forum Video ConversionReplies: 2Last Post: 5th Feb 2010, 10:24 -
help -- salvaging a 4gb avi file
By pkpara in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2009, 20:50 -
Shrinking an AVI file from 1.4GB to 700MB
By DVantrease in forum Video ConversionReplies: 5Last Post: 28th Mar 2009, 19:11 -
Extraction of raw A/V from AVI container for files >4GB?
By alfonzo in forum Video ConversionReplies: 22Last Post: 11th Sep 2007, 07:18 -
4gb Limit on SDHC Card, FAT32
By AVCHD in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 04:24
