I am trying to convert some of my old footbally highlight films to dvd. I just captured the first one and a white rectangle shows up in the middle of the screen every minute or so and stays there for about 10 seconds. I am assuming this is macrovision, but I don't know why this tape would be copy protected, because it is home made. I did a search and found some people recommending the SIMA CopyThis. WIll this remove the white box? I don't want to spend $50 if it isn't going to do me any good.
Results 1 to 20 of 20
screenshot?
NOT macrovision.
Off the top of my head, could it possibly be the "icon" some VCRs display when changing modes. ie : > play -
Is the white box there when you play the video on TV?
Regards,
Rob -
Originally Posted by rhegedus
The white box is not there when the video is played on a tv.
Possible - watermark from the capture software. What software did you use for capture?
To get a screen shot , get a copy of virtualdub - export frame. -
Originally Posted by holistic
The video is fine sometimes, then sometimes the white boax appears for a few seconds. -
After further reasearch, I think it may be a problem with the WDM drivers I am using. I am gonna try some older drivers and see what happens.
. O.K goodluck with that.
It will be intresting to know the fix.
Your computer is smarter than your TV. It knows the refs don't like instant replay, makes them look like airheads, so it puts a white patch over the play.
Bseball doesn't like the o'head camera to show you the HP Ump is blind as a bat, hockey doesn't like the over the net cam, either.
(Actually, I don't know the answer to your prob, but this looked like a good place to interject this. You never see this prob with Soccer or basketball, the ball is too big, every body can see what just happened.)
Never heard of such a thing, BTW.
Cheers,
George -
Hi JRW160,
You're on the right track - this is how these cards handle macrovision, but it is also triggered by poor VHS signals, typically from ageing tapes - I have had this problem myself.
My solution was to install the version 1.08 WDM driver, which is not macrovision aware, works fine now. -
This is not macrovision or any kind of protection. It is a well known problem of the nvidia cards. To solve it, you need the correct driver / software for your card (the "universal" drivers don't work for all cards...).
Read this, it might solve your problems:
http://www.tek-tips.com/gviewthread.cfm/lev2/66/lev3/68/pid/ 749/qid/155668 -
The problem I am having now, is actually getting the 1.08 drivers installed. I uninstall the WDM drivers, then restart. Then I run the 1.08 WDM installer and it restarts the computer. When the computer comes back up it finds all the new hardware, then when I install automatically it outs the version 2.20 drivers back. I can't figure out where to tell it to get the 1.08 drivers (install drivers form a specific location) or where to delete the version 2.20 drivers from.
Isn't there a a utility to wipe a PC and it's registry of drivers for your card? - check the Leadtek site.
Failing that, make a note of the files it copies to your PC and delete them individually.Regards,
Rob -
Satstorm is correct. It is not any kind of protection. I ran into copy protection on vhs three times. to solve, I connect vcr to my digital camcorder, use firewire to pc. Open windv and capture it. I do not record to camcorder since my cam has pass-through analog to digital. After capture movie, i use tmpgenc to encode and then burn. Movie is fine. Laterly, I also use virtualdub to edit the movie before encode it. Movie looked sharper and color looked much better.
Originally Posted by SatStorm
http://www.tek-tips.com/gviewthread.cfm/lev2/66/lev3/68/pid/749/qid/155668"Knowledge makes a man unfit to be a slave."
Frederick Douglass -
It is a "'usual" problem. Seems to happens randomly with nvidia cards (because of drivers / mobos / other crazy things), when you are unlucky enough.
There is always a solution, but you have to search for the right combo (drivers / capture programs).
The link I provided discuss this thing 3 years now! (it is focusing on asus nvidia cards, but the tips provided there can help anyone with those problems). -
Originally Posted by gmatov
LG RC278 (RC-278) DVD-RW/VCR Hack Options - Copy Protection question
By vicctor in forum DVD & Blu-ray RecordersReplies: 2Last Post: 8th Sep 2013, 15:31 -
Copy right protection on Glee?
By chiburu in forum Newbie / General discussionsReplies: 14Last Post: 24th Sep 2010, 10:47 -
Copy Protection
By Big Jake in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2010, 14:31 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 14:25 -
CD copy protection
By KingSeti in forum Off topicReplies: 14Last Post: 26th Feb 2008, 12:01
