Am I missing something simple here because I have never got this function to work
Load an avi, adjust setting to suit (dvd, 16:9, scale... es video only) add to batch list,
repeat for another file, but when I hit the Start encoding button the programe just quits![]()
If I save the projects, when I add a second project to the list it deletes the first project from the list!
Works fine just doing a single file!
I used Mainconcept to batch encode 38 mov and wmv music videos for my daughter. I added the file and chose "vcd" for the output of each file. After adding the file I clicked on "File" "Add to batch list". I repeated this untill I had all 38 files added. I then started the batch encoding and Mainconcept converted all 38 files to vcd. This worked for me. Not sure what your problem is.
Try to un-install and re-install Mainconcept. Probably something messed up with the location where it reads the pre-sets.
In any case, reinstalling it won't do any harm.The more I learn, the more I come to realize how little it is I know. -
Tried reinstall - still not working
Installed new 1.4.2 demo version and works now
Cheers anyway.
Mov to mp4 won't work
By Klagar in forum Video ConversionReplies: 1Last Post: 15th Dec 2010, 12:07 -
TMPGEnc Plus won't complete batch jobs.
By Timex in forum Newbie / General discussionsReplies: 2Last Post: 7th Dec 2007, 00:13 -
cd drive rw won't work
By sue1951 in forum ComputerReplies: 6Last Post: 27th Aug 2007, 14:39 -
ffmpegX 0.0.9x r2 just won't work under X.3.9 ?
By Jose Hidalgo in forum ffmpegX general discussionReplies: 1Last Post: 16th Jul 2007, 09:37 -
Autoplay on PC won't work now
By gwoiler in forum Software PlayingReplies: 3Last Post: 31st May 2007, 16:36
