  1. I have a concert on DV tape. Not in the best quality, cause before I copied it to the DV (PAL DV) it was on an NTSC VHS tape (had to do it this way). So its suffered some quality already because of VHS and conversion issues already.
    Now I want to put it on DVD and I wonder what quality and bitrate, interlace etc. settings I should use when I convert the DV to DVDmpeg via TMPGEnc. I got better results with using the Noise Reduction Filter in TMPGEnc by the way.
    Is there a TMPGEnc template that anyone would recommend? What bitrate would be best?
    I dont care how long this would take to encode, so I'd take the best quality settings; otherwise it would be nicer to have it fit on 1 and not 2 DVDs when finished.
  2. Try 352x240 and 3000 kb/s
