Did the searches promise. Formac video capture device. Capturing to DV/PRO. The movies and sound play fine in quicktime but no sound when importing to iMovie. Tried coverting to DV stream no luck. Checked all the system prefs everthing seems fine. Also I can take the same clip and they come into iDVD fine. Any ideas, thanks.
If the Thunder don't get you,
the Lighting will. -
I know you said you checked the prefs, but did you check the sound level slider in the GUI or the audio-track checkboxes (timeline view - far right) in iMovie?
Both channels are checked and the volume is cranked.
Well, since the sound works in the other apps, iMovie is the problem. Delete the iMovie prefs (.plist) to see if that helps - if not, reinstall it.
"Both channels are checked and the volume is cranked."
You might check to see if the very top box is checked. That is the sound that is "embedded" in the DV clip. I had the same thing happen to my daugher's movie and it drove me nuts. -
iMovie defaults the output of sound to your firewire device. Try turning off your Formac to make sure that the only thing iMovie sees as an audio out is your Mac's internal sound. This frustrated me to no end when it happened to me.
ffmpegX: no sound when converting a imovie *.mov-file
By acid_burn in forum ffmpegX general discussionReplies: 2Last Post: 27th Dec 2011, 01:40 -
From Vegas to iMovie - Does the version of iMovie matter?
By and in forum EditingReplies: 4Last Post: 11th Dec 2011, 21:05 -
iMovie output to anything, no sound
By rikyo in forum ffmpegX general discussionReplies: 2Last Post: 6th Jan 2010, 09:13 -
Using iMovie
By bobl in forum MacReplies: 2Last Post: 2nd May 2008, 21:08 -
iMovie HD 6.03 Project: Equalizing sound on movie clips?
By iMacMan in forum MacReplies: 2Last Post: 30th Jan 2008, 04:53
