Has the ffmpeg MPEG-2 encoder made any steps away from its "experimental" status yet? It's so wonderfully fast - it would be nice if it was now producing more usable output...
Erroneous Monk's FantomGuest
Major, I ran into a very weird, but GREAT result with the ffmpegX encoding tonight! Someone here suggested converting any avi's to fast divX, as it seems to fix some sync issues. it works nicely, and then I've been running the fastVCD settings to make my VCD's. After a few drinks, I messed up and somehow set it to the MPEG2 ffmpegX encoder, and the audio was mistakenly set at 48000 as well. It encoded like a rocket!!!! The output MPG played perfectly in both VLC and Quicktime, and just for laughs, I tried to author the streams in Sizzle.....and it worked PERFECTLY? Nice DVD, other than a little fuzzy because the default for the fastVCD is 352x280, but otherwise flawless? I thought the MPEG2 was supposed to be fixed in the NEXT version? Furthermore, my avi original source was PAL, and I set the fastVCD to NTSC!!!! I Just hope I can duplicate it!!!!
I had a play with the ffmpeg command-line tool for producing MPEG-2,.
The MPEG-2 that it produces althought very fast isn't quite compatible with the later stages of DVD authoring, but I found that after slpitting the audio and video out and then re-multiplexing as DVD compatible, the process is still quite a lot faster than the normal GUI based approach.
W.I.Bler
libfaac encoding with ffmpeg
By chicken264 in forum Video ConversionReplies: 31Last Post: 20th Dec 2012, 08:04 -
ffmpeg encoding mpegts
By adismsc in forum LinuxReplies: 10Last Post: 24th Nov 2011, 11:51 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 12:04 -
ffmpeg encoding issues
By nj473 in forum Video ConversionReplies: 0Last Post: 7th Feb 2010, 19:20 -
ffmpeg encoding help
By guitarscn in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2008, 16:11
