I have my DV tapes conversion down pretty good after a few weeks of reading and asking questions now I'm on to my old 8MM tapes. I use my DV camera to put in computer and I have a few questions. Should I split the 2 hour tape with two DVD's or should I put the two hours on 1 DVD? Plus when I do the conversion with TMPGEnc Plus 2.5 do I use the same settings like when I do DV tapes or should I change a few things like using CBR instead of VBR 2 pass? Any suggestions would be appreciated.
Thank's
No conceivable reason to go to CBR. Main difference from DV tape is greater likelihood of noise, requiring possibly higher bitrate or smoothing filters. Bitrate recommendation dependent on many factors, such as amount of motion, lighting, use of tripod, etc. Decision to split based on bitrate.
Question AVI Captured with DVSplit passing 8mm camcorder thru Canon HV30
By vtkahns in forum Video ConversionReplies: 0Last Post: 27th Feb 2010, 15:46 -
What is the best camcorder for 8mm to dvd.
By krlorenz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Dec 2007, 13:58 -
40yr old 8mm to dvd
By ACLUguy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 21st Dec 2007, 04:51 -
8mm film to DVD ????
By StuR in forum RestorationReplies: 31Last Post: 29th Nov 2007, 09:21 -
Top quality professional transfer of 8mm and Super 8mm film
By cosmichippo in forum Video ConversionReplies: 75Last Post: 25th Jul 2007, 21:28
