Hi all
I've having some probs....
I'm trying to convert a PAL Divx avi to a NTSC DVD to play on my DVD player.
I've been following this guild
https://www.videohelp.com/guides.php?guideid=447&howtoselect=4;10#447
If I just follow it...everything works but the burned dvd video has a slight jerk. this must be because of the pal to NTSC.
I've tried to change the framerate to 23.976 fps (internally 29.97 fps)
when I unlock the frame rate this option isn't there...So i've tried 23.976 fps. ( from this guild https://www.videohelp.com/forum/viewtopic.php?t=213817&highlight=pal+ntsc )
and hit start....hive me an error about the frame rate must be 29,97 or 25
How can I fix this?
this is the specs of the video I want to convert to a DVD NTSC
Video Codec: DivX5.11
Video Bitrate: 1155 kb/s
Video Resolution: 560x336- Qf 0.246 bits/pixel
Video Aspect Ratio: (1.67:1) [=5:3]
Audio Codec: AC3
Audio BitRate: 192 kb/s fs48000 Hz
Audio Channels: 2
RunTime Per Part: 01:12:25 (108,622 fr)
Number Of Parts: 1
Part Size: 700 MB (or 717,082 KB or 734,291,968 bytes)
Help
