Is Memorex a Cheap "second hand" media or is it a good media for less money?
Results 1 to 29 of 29
Never argue with idiots, they will drag you down to their level and beat you with experience
I use Memorex +R 4X media with code RICOHJPN01. This is one of the best on the market. The price is normal (not cheap and not such expensive like others with the same media code).
Just PERFECT! -
Memorex +R mdia=Ricoh=Good
Memorex -R Media=CMC=Not So Good -
Hmmmm....
I've used about 100 memorex 4x dvd-r's and have had over 95% success rate. (the only times it failed was when I was trying a new method or experimenting with compatabillity on older set-top dvd players.
But I've been very pleased with these discs JMO -
Memorex DVD's = apparently they're good, from peoples' reactions.
Memorex CD-RW's = ¡CR@P!-Yar, matey!- -
The Memorex CMCMAG -R's work perfectly fine on my Pioneer A05 and NEC 1300A. I wish they were still PRODISC.SO3's which worked fine even in my BTC 1004IM. I really feel safer buying from a local retailer rather than bulk from the internet anyway. Keep in mind that almost any manufacturer has put several different oem disks in there packages, Imation, Memerex, Fugi, ect. I like to think they require grade a material however.
Out of 100. I've had about 7 coasters from the Memorex White Inkjet Printables 4X (RICOHJPN). NOT BUYING THEM AGAIN.
To me they're garbage.
I had a 5 pack of -R's, and they
1.) had a 40% failure rate
2.) ruined my E50. I had to take it back and get a new one.
I wouldn't give them to a dog to play catch with...Mechworker -
I had about 30% failure rate with Memorex 4x DVD-R in jewel cases.
Sam Ontario -
Their 4X discs have been pure shit for me, but not their High-Speed CD-RWs with the blue jewel-case inserts. Those discs have been flawless since the first one I purchased. I must have 200 of them and not a problem yet.Memorex CD-RW's = ¡CR@P!
Sam Ontario mentions he has a 30% failure rate with his Memorex DVD-R discs. I've got him beat hands-down. I'll post the final numbers once they're tabulated, but I'm looking at 60% failure rate. -
Memorex Cool Colors CD-R are actually one of my discs of choice for music and data. Never a bad burn, though the reflectivity is not great (my laptop will not read it). I have a small stash of really old Verbatim and Pioneer CD-R for my laptop and picky CD player.
Memorex 4X +R Media=CMC=Good as well (found out recently)Originally Posted by GKar
Stay away from the Memorex -R. Most of the people have problem with Memorex -R, not +R. -
I've experienced quite the opposite.
Memorex 4x +R CMC = Shit at least on my burner. Lite-On LDW-451S
I just went through a 25 pk of Memorex -R's (Prodisc) and have had 1 coaster out of 25 I went out and bought another pack of 50 (Prodisc) and the first one failed. When I looked at the disc, it had a 1/4" scratch towards the end!!! It was straight out of the pack and not my doing. I'll just write it off as being damaged in transit. I will stick to them as long as they're reliable. -
After 200 burns, I have no coaster with my HP 300e &Khypermedia burners using Memorex 4X +R. They also work with the Imation 4X +R too.
No problem with Memorex DVD-R 4X on a Lite-On 451S. 15 burns no problem. $50.00 gets you a 50 pack of -R or +R at Best Buy after a $30.00 INSTANT REBATE!
Memorex +R 4x CMC = Excellent (on my NEC ND-2500A)
Although there are quite a few dissindents apropos of the CMC media here, you will find that in other communities, such as cdfreaks, there are proponents. Hell, my CMC burns are better than my RicohJPNR01 burns.
So for me TDK, Maxell, Imation, Memorex 4x DVD+R's are a win-win situation. I couldn't care if I got CMC or Ricoh. They both burn excellent and I have yet to burn a coaster. Don't get me started on Ritek and all the coasters i have made there. YMMV, so don't start flaming.
Cheers. -
Just got a new system with a Plextor 708A Burner and used Memorex DVD-R 4X for my first two DVD's. No problems encountered.
My only experience has been with a 25 pack of +RW 2.4X and they are CRAP. My Plextor 708A is able to burn them "sometimes" but even then I get occasional pixelation and audio popping noise. My complete burn failure rate so far has been 5 of 10. All 5 of the complete burns have some sort of problem (mostly minor).
The media code (DVDInfoPro) is INFODISCA01
Fortunately I only paid $19.95 for the 25 spindle so it's not a huge loss. Just frustrating. I'll stick with Maxell, Verbatim, TDK. -
I have a spindle of Memorex 4x -R
they are PRODISCS03
I bought a Lite On 811s and couldn't get a good burn unless it was burned at 2x, even then the movies would skip in my component player.
I returned the burner for a Plextor PX-708A, and it burns the memorex discs at 4x, and so far they all play perfectly in my player. I say so far cause I've only burned a few... -
My APEX DRX-9000 is fed nothing else! I'll take them. I actually need more.Originally Posted by indolikaaWant my help? Ask here! (not via PM!)
My APEX AD-1100W can bit-up your APEX DRX-9000...Originally Posted by lordsmurf
I had the exact same problem with my 451s... It turned them into coasters. I just got my 812s yesterday and burned a couple disks.. Both of them burned amazingly... PI was under 10, PO was under 6....Originally Posted by louv68
See that is why, I don't always want to fault the media. Sometimes the firmware just doesn't specify good write strategies.
Anyhow, this media is certainly better than a lot of junk. No names etc.
Cheers. -
Memorex 4x DVD+R=Bad Media for sure.
Out of a pack of 25, I had six successful burns with a brand new TDK 840G.
I bought a cake of 25 Fuji 4X DVD+R from Best Buy for $29.99, with $5 rebate, and have burned flawlessly. They're Richohs.
Also, bought two packs of 15 Maxell DVD-R from Office Depot...no problems there either.
Bottom line: www.nomorecoasters.com is right on target IMO...CMCs are landfill material -
@realdeech,
What CMC media code are you getting on those Memorex DVD+Rs?
I just bought some last night at Wal-Mart and they're still Ricoh discs in this area... -
Originally Posted by realdeech
No, your TDK840G burner is landfill material badly needs FW update. -
Don;t use Memorex DVD+R (RICOHJWP1 whatever) with 840G
I wound up with a bunch of coasters BECASUE it was burning it at 8X
no more.. I will keep it at 4X.. Firmware updated is available for it 1.06 at TDK webstite
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Bad DVD media
By PhoneMatt in forum Newbie / General discussionsReplies: 13Last Post: 19th Jan 2008, 11:01 -
Problems with Memorex Media. Where to buy Taiyo Yuden?
By John Shumate in forum MediaReplies: 11Last Post: 19th Dec 2007, 13:38 -
Memorex DVD-DL "RITEK S04" PLEASE UPDATE the media section.
By Crazyj32 in forum MediaReplies: 12Last Post: 13th Nov 2007, 02:28 -
Memorex DVD+R DL 8X Media Not Being Read
By Surfmaster in forum MacReplies: 10Last Post: 12th Nov 2007, 12:59
