I created a DVD and currently have it saved as a VIDEO_TS folder. Later on I realised I'd made the rather foolish mistake of messing the date up that appears on the main menu.
Is there any way I can alter this without having to re-capture the footage and re-athoring it?
Thank you!
You definetely don't need to re-capture or re-encode. You can demux the assets and re-author. Many tools are available that can do this - Vobedit, Vobrator, DVD-Lab, TMPGEnc DVD Author.
Depending on your experince and knowledge of the DVD architecture you don't need to re-author either. If it's just a menu still image you want to modify you can do this (more-less) easily with Vobedit and Menuedit.
http://forum.doom9.org/showthread.php?s=0c4398a2d424425ff4cbe85aeb405a93&threadid=70674
recreating vob ifo files
By krohm in forum Authoring (DVD)Replies: 25Last Post: 15th Jun 2009, 06:27 -
What should i do with vob/ifo files?
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 2Last Post: 16th Dec 2008, 02:26 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 08:31 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 14:38
