I burned a DVD-R to play in my above player. I have never had any problems with any of my homemade DVD-R's on this unit. When I insert my new one I just burned, I get the above error message and I cant figure out what is causing it.
FYI, I play the same DVD-R in my desktop and laptop computers just fine though.
Any ideas what that message is?? If you know what the problem is, how can I fix it?
The oqners manual wa no luck either. It never referenced the message.
sellpipe
I seem to recall seeing the same error on my Sony Player... Turned out it was a PAL format disk. I believe you'll see the same message if you use a disk made for a different region. I ended up playing the PAL format on my Apex, rather than recoding from PAL to NTSC. One screw-up by encoding to wrong format was enough.
Good Luck
"Playback prohibited by area limitations"
By zork152 in forum DVD & Blu-ray PlayersReplies: 20Last Post: 1st Sep 2014, 16:29 -
play back prohibited by area limitations
By tron1980 in forum Newbie / General discussionsReplies: 1Last Post: 13th Apr 2012, 23:21 -
Samsung HT-Q 20 Firmware Update "Play prohibited"
By germandvd in forum DVD & Blu-ray WritersReplies: 5Last Post: 21st Feb 2010, 11:06 -
Playback prohibited by area limitations >8(
By Flare in forum MacReplies: 3Last Post: 17th Jul 2007, 18:38 -
Sudden "Playback prohibited by area limitations." problem
By ph1losophe in forum Authoring (DVD)Replies: 11Last Post: 16th Jul 2007, 23:46
