    Mar 2004
    Houston, TX
    Okay I downloaded the 2 softwares but I can't get it to work right. After I decrypted it, I tried to back it up with shrink and when i tried it it would always say "I/O error" and it would say stuff like it is copyrighted or ssomething along those lines. what am i doing wrong? Is there somebody on here that's willing to chat with me on AIM and help me out with the steps? I used DVD X Copy previously and i'm getting pixelation. I want to be able to burn a clean copy. Thanks.
    Apr 2002
    The State of Frustration
    Have you tried playing the DVD's main movie while ripping?
    Hello.
  3. If you are serious about what you are doing, my suggestion is to read the guides in the forums. Ask questions where you do not understand in the guides. You will be much more successful than simply getting frustrated.
    I still consider myself a newbie after burning over 100 DVDs. I still read up and check out the forums. I learn new things all the time.
    (By the way, thanks Toronto098, good motivations)
  4. If you still have problems download AnyDVD and CloneDVD 2, if you want ultra easy - 30 day trial.
    Mar 2004
    Houston, TX
    I followed instructions through the guides on various sites and is till can't get it to work. I still can't figure out what i'm doing wrong. I don't think my Pioneer burner likes DVD X Copy as it gives me burns with pixelation.
  6. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    what specific guide are you following? and at what step do you have problems?
    this looks like a good guide http://www.doom9.org/index.html?/mpg/dvdshrink31-main.htm
    i personal like the guides on this site www.dvdshrink.info
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Download Smartripper and follow the guides here for the two softwares.
    EDIT: Thanks, dude, fixed
    If in doubt, Google it.
  8. Member Sifaga's Avatar
    Aug 2003
    hey jim,
    check your link, take the b out of nbet and it works
