IF i have vcd ready Mpegs, and I put them in sizzle and make a dvd out of them, will it play fullscreen on my tv? I meen is it worth it to that when i can encode it, but wont it be the same quality? So should i, or shouldnt I?
thanks
eric
It should work just fine. Fullscreen and all. I wouldn't suggest re-encoding them cause that takes time, and you shouldn't have a problem with the method you suggested. I've used this technique to get several dozen Simpsons VCDs on to one DVD.Originally Posted by peacefrog226If it isn't broken, take it apart and find out why.
blog: deadsierra -
it will play at whatever aspect ratio your files are at.
typically VCD is fullscreen size so yes it will play fullscreen you should have no problems at all
are you asking jut to ask beofre you start the process? or asking because you have a problem?
Sizzle help
By danielmak in forum MacReplies: 3Last Post: 3rd Mar 2010, 08:37 -
Dealing with VOBs, subtitles, Sizzle and Miyu
By silverspell in forum MacReplies: 4Last Post: 25th Feb 2009, 07:57 -
How do I do this with Sizzle (dvd authoring tool)?
By master_debator in forum MacReplies: 0Last Post: 27th Aug 2007, 14:45
