Hi,
Sorry if this has been posted before but I want to know about PAL interlacing compared to NTSC interlace. When I have tried converting an NTSC interlaced DVD I have to use a de-interlace filter. I don't have to use anything with a PAL interlaced movie, it seems that all the frames are progressive, they don't need any filters using to correct the image output. Can someone help me out and explain why this is?
Another example. I have all 3 series of Family Guy on DVD PAL. When I checked the stats for all DVD's it says they are interlaced, but the first 2 series need a de-interlace filter or the resolution halving to correct the image on a PC monitor but the third series is fine, it doesn't need any de-interlace filter even though it says it's interlaced.
Thanks for any replies.
Everything plays interlaced whether or not it is stored that way.
For NTSC Film you just have to resize to 720 x 576 and re-encode
and set the frame rate to 25. Then change to audio to 25 also
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
Question about PAL & NTSC ripping and re-authoring
By Jack_Dante in forum DVD RippingReplies: 6Last Post: 23rd Mar 2010, 14:39 -
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 13:21 -
Procoder PAL adaptive interlace vs virtualdub
By telefunken in forum Video ConversionReplies: 1Last Post: 6th Mar 2009, 04:36 -
(De)interlace problem on PAL TV
By Srivas in forum Newbie / General discussionsReplies: 2Last Post: 5th Dec 2007, 14:17
