8) I guess thats good... if you want to lug around a DVD burner that is half the size of a notbook computer...![]()
and if you DO want to lug that around, then you could drop $50 more and get double the writing speed of 8x!
8x Digistor External Dual Drive DVD±R/±RW $139.00![]()
But seriously... slim line dvd burners are SIC!
You can nearly hold it in your pocket, check out the pics here under the tab "item includes" (that is the newer 4x±R/RW one)
Or if this shows up:
Results 31 to 33 of 33
That slim one that you showed is $245Originally Posted by Electrox3d
The one I posted was $85 with nearly the same features except for DVD-Ram (which can only be used on DVD-Ram drives or DVD-Ram set top recorders)
Also 4x DVD speed can burn theoretically in about 18min 30 sec
8x speed is 9min 15 second real world takes a little longer being the fact the the quality 4x media is going to be a lot cheaper than the quality 8x I wouldn't mind waiting for about 20min per disk using a $85 external DVD writer
Like I said its differnt strokes for differnt folks a larger drive is fine with me if it saves me $160
But I definitely agree the slim drives do look great and are pretty slick.
I have a dvd writer built into my laptop though so I dont need one but
Since you have posted people can see that there is more than one option and a few choices
Which is a good thing
IMHO
PS2 DVD Region Free Code
By THRobinson in forum Media Center PC / MediaCentersReplies: 0Last Post: 28th Dec 2010, 11:59 -
PS2 and DVD info from region1 moving to region 2. confussed totally here
By joelliott in forum Newbie / General discussionsReplies: 7Last Post: 14th Dec 2010, 15:52 -
Using my UK PS2 in the US
By ob7777777 in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2010, 22:36 -
Playing ripped dvd in ps2
By hrgrosskopf in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2008, 08:04 -
Burned DVD plays OK on standalone - not on PS2!?!
By offensekilla in forum Authoring (DVD)Replies: 5Last Post: 31st Jul 2007, 11:07
absitivly posilutly correct!
