  1. I want to put some avi's on a dvd using recordnow dx. Is there anyone that can tell me how I to do that. I also have sonic my dvd, I have been able to burn a dvd with that but it will only let me put like 70 minutes on each dvdr. Could someone please help me. Thank you.
    Monroe, Mi
    check the guides to the left. you will find what you need. if you have any SPECIFIC questions, then post back here
  3. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    You need to convert those avi's to mpeg2, and then author to a compliant DVD file.
    TMPGENc Plus will convert your avi's to mpeg2, and TMPGEnc Author or Ulead Movie Factory will create your standalone compliant folders.
    Good advice, , but a link to a specific guide doesn't hurt, does it?
    Will Hay
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
