I used the ntsc template in TMPG and the conversion to MPEG went fine and then I cut it with TMPG to 600mb (no bitrate errors like before). That's the good news.
I then used Roxio CDC5 to burn the VCD. Again, no problems.
The bad news is when I put the VCD into my Sony DVP-s530P DVD player, it still says "no disc".
What next?
Is there a way to use TMPG to burn the VCD and not have to use Roxio CDC5?
If definitely the CDs. CD-RWs work great. CD-Rs don't work on this DVD player.
Does anyone know if "any" CDs defintely work on this player? -
Have you done VCD's which require 2 disks for the whole movie. When I do this the first disc works OK but I get a "NoDisc" error in my DVD with the second disc. Is there anything special you need to do when writing the second disc?
On 2001-11-03 16:11:06, staind_96 wrote:
Roxio cdc5 works great every time i use it. it must be your dvd player.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
Need help burning a 700mb file onto a disc to be played on DVD player
By chaoscreater in forum Video ConversionReplies: 7Last Post: 11th Jul 2008, 04:20 -
Problem with Norcent DVD Player, Tray keeps open/closing, tray disc error
By daveshostack in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Feb 2008, 11:41 -
"Unknown Disc" error for all DVDs - is my player dead?
By RosieP in forum DVD & Blu-ray PlayersReplies: 6Last Post: 8th Nov 2007, 07:49 -
Burning my first DVD home movies with Pinnacle, "disc error" on D
By tony777 in forum Authoring (DVD)Replies: 2Last Post: 13th Jul 2007, 21:07
