When using TMPGEnc to convert Divx files into DVD, in the last step of the wizard it tells me which resolution to use 720 x 480 or 352 x 480, i have always used 352 x 480 because i tought that if i used 720 x 480 the resulting filesize would be bigger, but i was wrong, i noticed that if i use 720 x 480 the filesize is the same as if i were to use 352 x 480, so my question is: do u think that if i use 720 x 480 the resolution is gonna be better than if i use 352 x 480 when playing on a DVD player? , or is it just gonna be the same quality?
Thanx in advance
J.J.![]()
file size would be the same but you would need to allocate more bits (e.g. bigger file size) to get the same quality in each. E.g. if you want the same # of bits / pixel, you need a bigger file size for 720x480 than for 352x480, all else being equal.
"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole." -
You're probably using the exact same bitrate for both resolutions and thus the identical file sizes. The file size is a function of duration of movie and bitrate but not resolution.
All things being equal, the 352*480 will give a better "visual" quality with mpeg4 (divx) to mpeg2 encodes. This is because there is more information available for allocation to each frame....do u think that if i use 720 x 480 the resolution is gonna be better than if i use 352 x 480 ...
An anology : Spread some butter on a small cracker (biscuit for some of you) THEN spread the same amount on a piece of bread. The smaller item (cracker) has a thicker 'spread' . Such is the way the bits will be allocated to the 352*480.
STOP IT!!! You are making me hungry.
No, I'm from Iowa. I only work in outer space.
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 07:57 -
Resizing video resolution and video quality
By Timex in forum Video ConversionReplies: 13Last Post: 23rd Aug 2011, 22:08 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
Video Resolution
By dazealex in forum ffmpegX general discussionReplies: 0Last Post: 15th May 2007, 15:46
