  1. I have just noticed after putting a beautiful menued DVD together that DVD-LAB is not synching up audio right with the way it splits chapters. I know it's not the encoding of the video and audio because when I use TMPGEnc DVD author (with no chapters) the movie works fine. Any work-arounds? It seemed ok to work with at first, but 2/3 have had this problem....Argghhh..... I authored with DVD+RW and TMPGEnc DVD Author, then tested on DVD player, looked great. Whip out DVD-lab to make a nice pretty DVD and get crappola.... Should I just abandon it and use TMPGEnc DVD Author?
  2. DVDlab is good for Menus,if u want less greyhair,USE TDA..
  3. Lets work on this..
    What r u importing
    Vob filewith AC3/mp2/5.1/????
    what ver of DVDlab,i hope its 1.3
  4. During the final complile dialong box, under Multiplexer Engine, select Alternative instead of Main. Did that helped?
    Are you using Tmpgenc to encode your movie?
  5. I was using 1.3 -just upgraded to 1.4beta. Movie plays fine with tmgenc dvd author and no chapters. Did video with TMPGEnc, ac3 sound. Standard stuff. I can only assume it's DVD-lab since there are no issues when TMPGEnc DVD Author and NO chapters.
