I've just started playing DivX movies on my TV from the PC using the TV-Out on the soundcard and composite video-in on the TV. Works great with my 9600XT. However, I lack the necessary cable to go from my sound card to the TV. Borrowing a picture from this site, it looks like this:
Where would I find one of these or how can I make one? I have all the plugs and plenty of wire, I just don't know how it would be wired!
If you are talking about the 1/8" mini plug to the 2 male RCA plugs, that's a standard cable. Should be able to get it at most stereo, electronics stores.
In the hopes you are a U.S. or Canadian, I would suggest taking a printout to the nearest Radio Shack. Otherwise, try to find a good stereo, or audio video store. The cables are quite common and I do believe they should have them in stock, and may have the schematics you need as well.
Hello. -
Yep...the only "audio" cable in that picture is a 1/8" stereo mini to two(left-right, red-white)male RCA plugs. How many do you want??....I have at least 3 of them.
If searching an electronics catalog the "latin" name is:-
Stereo Mini Din (M) to twin RCA (M)
The M just means male and is often not included in the
desc. -
Thanks, that's very helpful! I'll take the info to Radio Shack today.
Laptop to Tv no audio with RCA cable
By syboz in forum Newbie / General discussionsReplies: 12Last Post: 5th Mar 2012, 21:13 -
HDMI Cable - Audio ???
By blinky88 in forum ComputerReplies: 8Last Post: 27th Apr 2011, 08:23 -
audio with hdmi cable?
By eligen in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2009, 01:35 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 13:21 -
PSU with detachable/modular cable management Vs stable cable(Recommendation
By retroborg in forum ComputerReplies: 3Last Post: 15th Oct 2008, 15:50
