  1. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    I have a home movie and wish to add a few comments over the original soundtrack. Can this be done easily, and can you suggest a program?
    At the moment I am just stripping out the soundtrack and replacing it with a commentary. Thanks.
    "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    I'm not sure what format your video is in but...
    I did something similar to this using some voice recording software, doesn't matter which one, which I used to record my voice while at the same time playing the video (with audio turned off) in a seperate window. I took the resulting voice audio, in my case MP3 format, and combined it with the original video using Womble Mpeg Video Wizard. I'm sure there is other video editting software which can do the same thing. You can also add a soundtrack this way.
    The reason I chose Womble is because I was using VOB's from a DVD recorder.
  3. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    Thanks, My video is mpeg2. I will try that. BTW, I suppose I could record my voice with my DV camera, then strip the sound and then merge.
