Hi, I try to convert WMV to AVI using Stoik video converter, and I convert the audio to MPEG Layer 3, but it always said "CANNOT OPEN OUTPUT FILE". But if I change the audio to PCM it works fine.
What is the problem?? Should I install some plug-ins for MPEG Layer 3 conversion udsing Stoik?? Thanks.
Originally Posted by mersiung
If it's not critical that you end up with AVI files, my suggestion would be to forget Stoik (too buggy) and use TMPGEnc to convert to MPG
in order to do so, you'll need at least DirectX 8.1 or later and you'll also need to install the windows media format 9 runtime files if you haven't fully installed WMP9.
File Issue Using Any Video Converter ???
By musicmad in forum Video ConversionReplies: 3Last Post: 4th Apr 2012, 15:57 -
unable to open video file
By edu4rd in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2011, 14:22 -
Video Converter FREE OPEN SOURCE
By Catzface in forum Newbie / General discussionsReplies: 5Last Post: 5th Dec 2010, 06:20 -
can't open video file
By Shotobits in forum Newbie / General discussionsReplies: 2Last Post: 20th Mar 2010, 05:08 -
Limiting File Size in AVS Video Converter
By TJF in forum DVD RippingReplies: 6Last Post: 27th Nov 2009, 14:20
