Can anyone please tell me what is the best resolution I should scan pictures ( slide show) to record on a dvd? Please note that I am using a progresive scan dvd player connected on a projector (1024X768). Shall I use the 720X540 dvd player output resolution, or 1024X768 video projector resolution?
thank you
Use a DVD compliant resolution. There's no benefit scanning above that because your authoring application will resize it to 720 x 480/576 (NTSC/PAL) anyway.
Originally Posted by petar
True but that will depend on how he wants to set up his slideshows. The way I understood Andros' question is whether the higher resolution of his projector (over the DVD resolution) will make any difference to the pictures recorded on the DVD. The answer to that is no. But to add effects to the slideshow then yes and in that case probably best to scan in the highest resolution his scanner can handle.
Photo Slide Show in AVCHD
By chrisnewton in forum Authoring (Blu-ray)Replies: 8Last Post: 23rd Apr 2011, 03:40 -
dvd w/ video & picture slide show
By hymnatr in forum Authoring (DVD)Replies: 2Last Post: 20th Dec 2008, 10:51 -
DVD Slide Show Duplication
By KLouis22 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2008, 07:27 -
Adding slide show to a movied DVD
By leungf in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2007, 08:55 -
any way to make changes and not to encode entire slide show
By tryintoo in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 17:02
