i am using nero 5.5 and have just installed a lite-on 851s dvdr.now nero picks up my device as an image drive.i can watch dvd`s through my lite on but can not burn them? the only discs i got with it was power dvd xp and my dvd software,neither contain the driver for it.neither driver guide or lite-ons main site?????? please help
Can you go up to the main menu (tools, I think) and "Choose Recorder".
Let me guess - your version of Nero came bundled with one of your old drives, right? The same thing happened to me when I switched from TDK to Pioneer. Your version of Nero will only work with the burner it came with.
I'd rather have a bottle in front of me than a frontal lobotomy. -
GREAT answer YngwieJM, I had forgotten all about some Nero OEM versions being locked to one burner. Pretty crappy for a guy who just wants to upgrade his burner.
Maybe my memory is failing but didn't you get a message saying something like "this version can only be used with the burner it shipped with" or something like that. I seem to remember getting a message like that when I swapped my two burner.
tomoftenville, can you give us more information. Did your Nero come with your old burner (if I remember the sleeve has a sticker on it saying "can be used with this burner only". -
This happen to me
Nero 5.5 was picky if theres a diffrent burning software on your pc.
So if you have diffrent burning software try uninstall it. -
i borrowed nero 5.5 from a freind of mine.he had a creative cdr and i have a samsung cdr.nero worked fine with both drive`s.all i have done is change my cdr to a dvdr and it is only picking up as an image recorder.
nero 6 detects my dvd drive
bnow need an author tool to create vob files.thanks for your help
Question about restoring C drive from Ghost image
By jimdagys in forum ComputerReplies: 11Last Post: 24th Aug 2009, 14:24 -
AviSubDetector picks up everything on line
By kpic in forum SubtitleReplies: 0Last Post: 26th May 2008, 08:45 -
Warner Bros. Picks Blu-Ray Over HD-DVD
By David K in forum Latest Video NewsReplies: 1Last Post: 5th Jan 2008, 15:13 -
is there a freeware tool for making an image of my c drive?
By surfmonkee in forum ComputerReplies: 17Last Post: 10th Nov 2007, 21:01 -
Requesting DVD/CD Drive Picks For Audio Rip Quality
By luigi2000 in forum AudioReplies: 3Last Post: 2nd Aug 2007, 10:28
