  1. Hi again.
    I`ve used this guide.
    http://www.doom9.org/index.html?/mpg/maestro2.htm
    to make my own dvd. I`ve ripped the sound to ac3 format, and the movie to m2v format. When i used Maestro to put it all together again, the sound and my own subs that i`ve putted on was out of sync. The sub sync was getting more and more out of sync, but the sound didn`t move further out of sync in the middle or the end of the movie comparring to the start of the movie....
    Please someone..... Help me! Have putted so many hours in this project, and i can`t and won`t give up.
  2. Please specify what exactly are you trying to do /insert subtitles?/.
  3. Yes... Inserting subs.
    But the sub is out of sync. And likewise is the sound when the movie is done. The sub gets more and more out of sync the longer i get in the movie. In subrip i saved it as a .son file in 30 Fps, but the original movie runs in 23,something Fps. Can this be causing the error?
    The sound problem leaves me point blank...
    Any help or suggestions will be a good help.
    Regards.
  4. Everytime I try to insert subs into Maestro, I face the same problems as you do.
    I have checked that the subs are in sync when playing the movie with Vobsubs and have resigned myself to the fact that Maestro has trouble inserting the subs.
    My solution to the problem is to use Subtitle Workshop to correct the sync, save the subs, before previewing the movie in Maestro. Doing this several times normally gets the subs in sync for me.
    Regarding your sound sync problem, I have not encounter such problems before. Perhaps trying to sync the audio to the video might help. Check out this feature in your Maestro manual.
  5. Member Zetti's Avatar
    Dec 2003
    Canada
    I always use Maestro sync feature, it works, never used subtitles;
    If you have sound sync issus even after using the sync feature, I'd guess the problem lies outside Maestro;
    Zetti
  6. My solution to the problem is to use Subtitle Workshop to correct the sync
    I`ve used Subtitle workshop to create the sub. So i don`t think that i quite understand what you`re trying to explain to me.
    The audio sync question!!!
    I just think that i rather need to try from the start again with that isue.
    This dosn`t mean that you all not are welcom to come forward with your help solutions....
    Quote: Knowlegde is something you don`t have before you have learned.
  7. At last!!!! Everything works out fine. There`s just one more problem:
    When i burn the movie out, the subtitles is nowhere to find.
    PLEASE!!! Someone please help me... My hair is beginning to turn to the gray end of the scale. *G*
