Results 1 to 18 of 18
    Apr 2003
    i am attempting to convert an AVI file to DVD i tried this a while ago and it work my problem is i am following this guide
    http://www.donstevenson.net/myguides/myguides.html
    and when i get to step 6 (using CCE) i cannot open it due to trail being expired, however if i uninstall the program completely then download the program again i get the same error,
    what can i do as i would really like to convert this file?
  2. you could buy cce, then you wouldn't get the trial expired message.
    Yes, I am a Pooternerd
    Apr 2003
    i can't afford to buy unfortunutly (cant spell)
    is there anyway around it? ie different guide, program crack?
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator Craig Tucker
  4. Have a read through the guides in the green section on the left, and please don't ask for cracks.
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Originally Posted by mickle
    ...please don't ask for cracks.
    That's funny considering your avatar!
  6. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    CCE BASIC is only $58.00 USD
    It lacks some features found in the more expensive CCE SP but overall it works pretty much the same and produces just as excellent quality.
    - John "FulciLives" Coleman
    Link to buy CCE BASIC for $58.00 USD
    http://www.visiblelight.com/mall/productview.aspx?sku=CCEB
  7. Originally Posted by ZippyP.
    Well spotted that man.....
    Apr 2003
    yeah but im a student! think that says it all.
    p.s sorry mods didn't know i was breakin rules!
    pps mods/admins, how long do warnings last? please pm with details if possible
  9. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Find a cheaper hobby then.
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
    Apr 2003
    its not a hobby
    mickle i have tried the other guides but most of them you need to use CCE or TMPGenc and this does not work correctly on my system either
    is there any way i can completely remove the CCE i have now, i have tried add/remove programs
  11. Member FulciLives's Avatar
    May 2003
    Re-format your HDD and re-install WINDOWS OS from scratch.
    Apr 2003
    but won't that remove everythin from my HDD?
    also relised that im having the same prblem with copytodvd, however with this i have removed it then re-installed is, but this does not work anymore
  13. Member FulciLives's Avatar
    May 2003
    Well you want to get rid of CCE don't you?
    Apr 2003
    yeah but like i said i've managed to remove it before when it expired and then re-installed it, how come it won't work now thats what im tryin to find out
  15. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Try TMPGEnc. That program has a free trial period so you can use it for a while without having to pay for anything.
  16. I've never seen two yellow cards issued in a single thread before...
  17. Some programs put a hidden file somewhere on your computer to tell it when your trial has expired. the best way to get around this if you want to keep using the program is to buy the program. You could format and reinstall everything but I would rather buy the program or take it off if I didn't want to buy it.
  18. Member Conquest10's Avatar
    Chicago, IL
    its not a hobby
    Then $58 shouldn't be too much.
    His name was MackemX
