is there a plug-in that lets add looping to a imovie, final cut express or toast?
When you go to master your DVD with DVD Studio Pro, you can set up looping for specific video or audio tracks, so that it will loop forever. You can't just have a video file loop forever, or it would be infinitely huge. Other DVD mastering software for the Mac do not have that capability.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
In iDVD 4, you can drop a movie into the autoplay well (from map) and then click on the looping option under the advanced menu.
Importing VOB files--iMovie, Final Cut Express? New to Mac
By Theresa in forum MacReplies: 14Last Post: 7th Apr 2009, 09:54 -
Best program to get clips from factory dvd's into Final Cut Express
By Jabroni4872 in forum MacReplies: 1Last Post: 24th Mar 2009, 22:22 -
With a mac how do I convert a Final Cut Express item to mpeg2 dvd?
By dagardenguy in forum ffmpegX general discussionReplies: 2Last Post: 16th Jan 2009, 13:00 -
iMovie vs. Final Cut Express 4
By JediPM in forum EditingReplies: 1Last Post: 28th May 2008, 09:04 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 11:05
