  1. i'm using dvd decrypter to burn an image file thats 4.3 gbs but when i load it dvd decrypter says its theres not enough sectors should i go ahead and press burn anyways or is there another program i can use thanks alot
  2. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    langxjai, there is a thread in the forum a couple pages forward by
    dpagini84 posted on Mar. 23rd at 13:48. You might want to read it. I believe you should NOT burn it without reducing the size first. DVD Shrink can do that for you.
