I'm sure this is old news... but I'm looking at buying a new computer (HP or Compaq) and the DVD burners in those systems are DVD+RW drives. Will I be able to burn DVD-R(W) media in those same drives or will they only work with DVD+R(W)? Thanks for the help!
-DVD-Dude
Results 1 to 13 of 13
Originally Posted by dvd-dude
For only a few bucks / quid / euro more you should be able to get a dual burner that'll do +/-R & RW.
If the vendor won't put one in, look elsewhere.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Hope your getting a good deal cause you'd be better off with a homebuilt computer. If you get a P4 and you can have 800mhz hyperthreading for $30 more do it.
Originally Posted by Vanderlow
Some people are of the opinion that it's easy to "stick it all together" coz there's only one way it can go together. True, but do they know how to handle memory, the dangers of static electricity, which slots are best for which cards etc.?
It's that sort of knowledge that home-building a PC requires. In the UK, you can expect to pay around £25 - £30 per hour, with it taking about 2 - 3 hours to build and make sure all's OK.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
I have two homebuilt computers (built myself) and have had no problems because I know what I'm doing. In my work we have purchased "generic" computers if you like from computer stores as well as name brands direct from supplier and I have to say that we're leaning towards name brands as better. From a corporate point of view, we have found the warranties and service to be much better from places like Dell than the local store. It is at a price though, but if money is not an issue and your own knowledge pf PCs is not great, it may be worth sticking to a name brand.
If in doubt, Google it. -
Mass produced computers are too propriatary. Other than adding memory or a hard drive, some are not very easy to make upgrades. They are designed for speed of assembly. Even the cases are sometimes unusable for common ATX motherboards.
I would bet that most of the people who participate in this forum build their own computers. Knowing what is in the 'box' has a lot to do with understanding why something may not be working. It's a great education to build your own computer.
On the other hand, if you are not a person in constant upgrade mode, and plan to make no changes. Shop for computers that are built for what you plan to do. Example: If you are going to be doing mostly multimedia, don't buy one that is generally used in a business environment. I've seen some pretty nice 'Multimedia' computers and they do tend to cost a little more. Don't depend on the salesman, read, read, read. Good Luck!If it works, don't fix it. -
New HP/Compaq PC's ship with 8x DVD+R/4x DVD+RW drives(or sometimes 4x DVD+R/4x DVD+RW is specified as a cheaper option)
The 2.4x DVD+RW only drives disappeared off the scene about 18months to 2 years ago!
KDH -
Originally Posted by KDH
Sorry, I understood that DVD-dude was" looking at buying a new computer (HP or Compaq)..................
I've never seen a drive that will only do -R or +R without doing the corresponding RW part (maybe a few years ago but not in this day and age)
makntraks
newbie question pioneer dvr-433h hard drive restore?
By isakiel in forum DVD & Blu-ray RecordersReplies: 4Last Post: 19th Nov 2011, 05:06 -
DVD to storage drive, best media player for dvd playback- newbie questions
By omkls08 in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2009, 10:22 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 04:18 -
Newbie VHS, DVD, Hd DVR To hard drive
By cougs_83 in forum Capturing and VCRReplies: 2Last Post: 21st Feb 2009, 08:52 -
Newbie Question: Can I use Alcohol default settings to burn DVD-5?
By ShadowRider in forum DVD RippingReplies: 1Last Post: 11th Aug 2007, 14:56
