  1. I have a pioneer 107D Firmware 1.12, Official! I want to know is when will they let me burn dvd's at 8x officially. I don't want to use Hacked Firmware as it will void my waranty! Dou think they will ever let me burn 8x speed on a 4x media? Or will they let me buen at 8x speed on only 8x speed media
  2. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    you have to use the 8x firmware which is different to the 1.12
    i can burn 4x discs at 8x with no problem
  3. I know that but that firmware isn't official!
  4. 1.12 official firmware is out now, problem is i used the unofficial firmware and now i want to do the official one it wont let me
  5. I am having the same problem with my Pioneer 107D. I upgraded to the hacked firmware version 110. Now I cannot upgrade my firmware to the official version 112.
    On another point, can anyone help with this problem I am having:-
    I have hacked firmware 110 and have tried burning full discs using:
    1. Ritek Orange -R 4x (G04 dye) at 4 x and 8x
    2. Datasafe -R 4x (G04 dye) at 4x and 8x
    3. Ridisc -R 4x (G04 dye) at 4x and 8x
    4. Datawrite Red V2 -R at 4x and 8x
    5. BulkPaq Orange -R 4x at 4x and 8x
    6. Bulkpaq White +R 4x at 4x and 8x
    The problem is that none of these will even burn at 4x.....a full disc (4.3gig) takes 20-21 minutes just for the burn process. So my Pioneer 107 is no better than my previous NEC1300a. Am I doing something wrong here? Why is it that others boast of writing at 4x and 8x with a 107 when best I can do seems to be 2.4x????
  6. Originally Posted by cotc2001
    Go to http://flashman.rpc-1.com and get this file "OFFICIAL_PioneerDVR-107_v1.10_DVRFlash.zip" update the drive then you can use the official 1.12. I'm sure there is an easier way but this way was fast and I worked for me.
    Rick
  7. I just ran the "OFFICIAL_PioneerDVR-107_v1.10_DVRFlash.zip" update and it said it had failed. Then I ran the v1.12 update from Pioneer and it was successful. So don't let it throw you off if it says it fails, just run the next update and it should be okay....
