  1. I'm using a GSA-4081B to burn, and it is burning on to the disc, but my DVD player won't read the DVD, my computer reads it at one but not my DVD Player, any reason why it would be doing this??? and how can I fix it, I know my dvd player plays backups because I used a different dvd burner before and it worked fine.
  2. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    Have you changed the type discs you are burning on ?,
    Are you burning with the exact same programs as before ?.
    What programs are you using and can you describe the steps you go through.
    Something has changed other than your burner or your burner is defective (not burning at the same intensity level as your other one). I suspect it is not the burner but something else that changed.
  3. nope haven't changed the type of disc or programs, I've always used the same 3 programs, but its not working on my toshiba players.
  4. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    Sorry, don't have a clue other than the burner (it's the only thing that changed, right). I did do a search on all forums with GSA-4081B and it turned up a fairly good size list of posts. You might read through those if you haven't already.
