Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Jul 2003
    Singapore
    Using TmpgEnc.
    After "cutting" a mpg file, the segmented video has no sound. I use Gspot to check the codec and it state
    "(S) --> MPEG-I Stream Splitter --> MPEG Audio Decoder --> (R)". What is wrong?
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Don't cut mpgs. That's the bitter truth. To be avoided at all costs. If you have to, use Womble mpeg VCR.
    /Mats
  3. Member Zetti's Avatar
    Dec 2003
    Canada
    Easy one, had a similar problem :
    If the cutting tool isn't precise, like TMPGENc, it misleads the very beggining of the cut track, so every video tool "thinks" there's no audio muxed in as it doesn't recognize the very beggining;
    Solution ? Easy, use Womble, very precise;
    Zetti
  4. Member teegee420's Avatar
    Dec 2003
    Southern California
    I have to echo the others here. Womble MPEG2 VCR is the best mpeg editor there is.
    Jul 2003
    Singapore
    Crapit, I'd been using TMPGEnc to perform conversion to mpeg1 format for many files. But I didnt realise the noise that is introduced until I wanted to extract the sound portion from a avi as it contain my favourite song.
    Jul 2003
    Singapore
    How do I do the cutting in womble2vcr?
