Dear All,
I just came back from delivery of my second son to discover that the video I shot during delivery is almost unwatchable! There is quite heavy distortion in the form of square blocks and entire horizontal lines of the pichture is distorted, moved to the right. Also the sound drops out when these distorions occur. I have purchased a cleaning tape an ran it a few times but it does not help with this particular tape. Other tapes play fine and I am also now (after cleaning) able to tape without distortions. So I gather this tape is probably not good and/or the video heads were dirty which messed up the recording. Is there any way I can correct this? Is there any software I could use? Camcorder is a Samsung VP-D77i and the tape I used was Maxell.
I would appreciate any and all help since this was a very special moment for me and my wife.
Thanks in advance! Lars
I have a Digital 8 camcorder that had the same problem. I too purchased a tape and ran it per directions (they read play, do NOT record) without success. I took it in to camera repair, and they charged $70? to clean the heads and the problem reoccured soon after. I ran the cleaning tape again, this time recording (against disclaimer on tape box). The camera now works like it should, and I haven't hit any problems.
I don't know the mechanics of digital 8 vs mini DV. I hope this helps you find the answer. -
Originally Posted by Ängsvik
It seems like most website that discuss this point more toward media than bad heads, although it does sometimes happen.
A few sites discussing the same issue:
http://www.photo.net/bboard/q-and-a-fetch-msg?msg_id=006f1G
http://www.videouniversity.com/wwwboard/techqa/messages/16614.html
http://www.camcorderinfo.com/bbs/t50003.html -
Dear All, Thanks alot for excelent tips and ideas! One follow up question, is there any recomendations to not use DV tapes more than once? Reason for asking is that I noticed slight blocky distortion on another DV tape of about the same age and usage. I usually tape one tape full, capture to PC, edit and make DVD and then use the tape over again. This tape is maybee on its third or fourth use. I thought DV tapes should have the same life as a VHS tape. Is this incorrect? Thanks in advance, Lars
recommendations here have been not to use more than 3x and some (/many, I don't know - maybe a poll would tell) use just once & store it, so what you say seems to fit w/ that...I am not the tape expert, but tape is still tape, whether it's storing digital or analog signal - metal particles on plastic w/ a binder..lifetime may be similar, but if you record & re-record on analog, similar problems will happen just present themselves differently...there are a few prior posts on this if you search around..
"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
How can I delete a "frozen" HDD recording on a Philips DVDR3575H/37
By pfflamingo in forum DVD & Blu-ray RecordersReplies: 19Last Post: 29th Sep 2011, 14:47 -
Mini DV + S-VHS Combo Decks: "SR" Pro Series vs "HR" Consumer Series
By jbd5010 in forum Capturing and VCRReplies: 0Last Post: 12th Apr 2011, 22:34 -
"Bitter Beer Face" Distortion
By dlflannery in forum Video Streaming DownloadingReplies: 3Last Post: 30th Jun 2009, 11:47 -
Video is "blocky" when capturing DV via firewire
By kongla in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 29th Jun 2007, 03:27 -
Philips PET725/78 - Distortion when .avi is "wider" than wide scr
By xXxAlvoxXx in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th Jun 2007, 12:37
