Hi guys![]()
Try this one. When I burn movies the playback on my standalone player keeps freezing after about 5 mins of playing. The freezing only lasts about a second a time but it drives you crazy when you try to watch a movie.
I am using Nerovision to decode and burn these and I have got an NEC 2500 burner burning Verbatim -R 2X discs. My DVD player is a venturer which seems to play almost anything including other peoples burnt DVDs. The discs have been tried on other players and they seem fine. Is there any way I can change any settings or recording methods to rectify this prob. One of the threads suggests you reduce the recording bit rate but nero vision seems to be automatic with no way of changing the settings.
I would realy appreciate any help you can offer.![]()
May I also take this oppertunity to thank everyone for a great web site ETC its great for us newbies to share all your knowledge.
Thanks a lot guys.
Gatamig![]()
This really is a pain, and as they play fine doesn't indicate the usal culprit; bad media.
I had a Wharfedale M5 DVD player, cost me £150 a couple of years ago and stutters all the time, yet my recently aquired cheapy £40 player plays everything, no problems.
I know this isn't helping but sometimes it's not down to your 'production' methods.
If you're backing DVD's (you don't say what your content is) try a different program, DVD Shrink for example, and limit the final size to 4200mb, just in case.
Good luck
Will Haytgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
I had a venturer that would do the same thing. They're pretty crappy players.
Thanks for the reply, and I thought my little Ventutrer was a goody. Still a complete home entertainment system for under 200 quid what should I expect lol. Mabye I should go out and get me a cheapy!!!
Freezing & skipping issue during playback
By Zumeraga in forum Video Streaming DownloadingReplies: 2Last Post: 4th Dec 2010, 19:55 -
DVD freezing?
By XyBeRz in forum Authoring (DVD)Replies: 10Last Post: 29th Dec 2008, 00:26 -
Subtitles freezing my DVD?!
By beter in forum SubtitleReplies: 3Last Post: 10th Oct 2008, 19:48 -
Freezing DVD-R
By markannab in forum Authoring (DVD)Replies: 7Last Post: 3rd Feb 2008, 04:01 -
Troubleshoot DVD Freezing
By melcher in forum Authoring (DVD)Replies: 2Last Post: 23rd Oct 2007, 12:36
