I am using DVDshrink to compress what I want to burn to a DVD. It says that it is small enought to fit on 1 disc. Then, I go to copytodvd and it says that it is to big to fit and do I want to continue. I tried to say yes and then it kicks out the blank and says it needs 13 gig which is way more than the original.
I'm taking a 2 sided disc and compressing it to fit on 1 side.
I've got a Pentium 933 with 256 meg of ram and a Liteon 411 burner. Burnt discs with this software before, although I just did increase the ram.
thanks
Results 1 to 1 of 1
Burning with CopyToDVD for DLP
By ckurowsk in forum Authoring (DVD)Replies: 2Last Post: 29th Jul 2008, 00:37 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
CopytoDVD Issue
By Cybrex in forum DVD RippingReplies: 1Last Post: 30th Jun 2008, 18:14 -
Error I get after I finish copying a dvd with copytodvd
By litzg5 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2008, 14:17 -
CopytoDVD states media does not have enough space - error message
By marke67 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd Sep 2007, 05:52
