I would like to know if I use DVD Workshop 2 with MPEG 2 files, if it re-encodes them even if they are in the correct format?
Machine Man, thanks for the reply. Can you tell me where I can find this setting, because I have looked and can't find it.
Thanks -
Yep, its not obvious where it is.
1. Got to Edit
2. Double click on the video in the timeline
3. Then click the Video tab on the top left.
4. At the bottom left there is a check box "convert to disc template" Don't check it if your video is compliant and you don't want DWS to convert it.
DVD Workshop 2 - No Audio in Windows 7
By KTH in forum ComputerReplies: 3Last Post: 27th Dec 2010, 16:08 -
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 02:04 -
DVD Workshop 2: Where is the best tutorial for this project?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2010, 09:09 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 02:48 -
DVD Workshop 2 on Vista
By jaffacaique in forum Authoring (DVD)Replies: 6Last Post: 22nd Aug 2007, 09:16
