Hi everyone,
First I'd like to thank everyone for the tons of information already posted here about audio synch issues. Each one seems very specific and over the last few months I haven't been able to find an answer for my problem. Here it is.
I have a 25 fps source having a VBR audio track (VirtualDub has detected an improper VBR blah blah...) and I want to convert it to a 23.976fps DVD. These are the steps I follow:
1) with VirtualDub-MP3-freeze I save the audio (direct stream copy) as an mp3.
2) I convert the mp3 to either CD quality or 48khz uncompressed wav. (both conversions yield same problem)
3) I convert the video from 25 fps to 23.976 fps and note the new length. I save this AVI with no sound.
4) I use CoolEdit pro 2 to stretch the uncompressed wav to the new length.
5) I load the soundless AVI into VirtualDub, use the audio>wav audio to select my new converted and stretched wav, and frameserve this to TMPEnc.
6) I author the resulting mp2/wav files with DVD-Lab and burn
What I end up with is a great looking film with awesome sounding audio which gradually gets out of synch. I have read every post on synch issues and nothing has worked.
Any help would be very much appreciated.
Thanks and keep up the awesome work!
I have tried saving portions of the video and it seems in synch.
I want to try to get away from having to save an entire uncompressed avi if possible, or having to recompress and lose the quality. -
After you have loaded the video and audio into Vdub and before starting the frameserver...play it from the main window in Vdub, move the slider to near the end where the sync should be worse. Is it in sync?
"Art is making something out of nothing and selling it." - Frank Zappa -
Zipp P. is correct. That's what i was getting at also, except, that if you do the extra step of saving the newly created interleaved .AVI, then it's bulletproof...
Good luck!! -
Thanks for the tips
When I preview the film or save off a segment it appears to be in synch.
I never thought about the fact that the direct stream copy would be fine in this case. I'm used to frameserving due to problems I've had with TMPGEnc not wanting to use the saved AVI file.
I will try this stuff out and post back...
Thanks again.
25fps-source Ac3 to 23.976fps
By Lastman369 in forum AudioReplies: 47Last Post: 26th Sep 2014, 02:19 -
[MKV] 25fps to 23.976fps? Tried and failed. Help!
By lag in forum Newbie / General discussionsReplies: 15Last Post: 20th Aug 2014, 12:27 -
25fps to 23.976fps
By Charmer in forum AudioReplies: 19Last Post: 8th Aug 2009, 10:41 -
Converting 30fps Progressive to 25fps interlaced ? (Avisynth & VDub)
By blewyn in forum Video ConversionReplies: 6Last Post: 12th Jun 2008, 17:51 -
converting 25fps to 23.976fps
By pannivas in forum AudioReplies: 1Last Post: 3rd Aug 2007, 16:49
