OK, i was wondering what you guys thought is the best way to convert from avi to mpg in order to make vcds. Also what setting are you using?
thanks
Results 1 to 1 of 1
Which Program Do You Use For Importing Video (MPEG) And What Settings?
By V Bot in forum DVD RippingReplies: 3Last Post: 10th Jan 2012, 00:54 -
What program/settings should I use to capture a home-made 8mm tape? (UK)
By kingmustard123 in forum EditingReplies: 2Last Post: 7th Aug 2011, 11:14 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
Vegas Pro 8 user with questions about program (and possible camera settings
By chuchunezbie in forum Newbie / General discussionsReplies: 0Last Post: 27th Apr 2009, 16:32 -
Is there any program out there that can determine source settings?
By steve003 in forum Newbie / General discussionsReplies: 1Last Post: 5th Mar 2009, 12:53
