My dvd player seems to be making funny noises and the picture is a little fuzy.it started to happen after i started using dvd-r,s in it and second hand dvds.iv tried cleaning it with dvd cleaner disk but no joy.my question is,is it possible for blank dvds to mess up your player?
movies do we watch them or do they watch us?
Maybe your DVD Player has just had it.
Have you tried the discs in another DVD player to see if they work OK ?
As for second hand DVDs - They shouldn't be any problem unless they are are dirty or scratched. The integrity of the disc should be the same as when they were new.
Also when you say
I presume you mean DVD-Rs with something on as opposed to Blank.is it possible for blank dvds to mess up your player -
yes i mean dvd-rs with data on them.the used disks i use are scratched and some have finger print marks on them.can this mess the player up?. iv only had this player for 5month,s maybe its the quality of the dvd-r,s or the ex rentals/used dvds that i buy from the net.
movies do we watch them or do they watch us? -
DVDs with scratches/fingerprints on them shouldn't cause you DVD player to make funny noises and it definately doesn't cause a fuzzy picture.yes i mean dvd-rs with data on them.the used disks i use are scratched and some have finger print marks on them.can this mess the player up?.
it must be my tv as i just tried it out on the other tv and the picture is crystall
Philips DVDR-3480 DVD Recorder and Player 1080i�
By Vixfoxwatch in forum Newbie / General discussionsReplies: 5Last Post: 7th Nov 2010, 15:18 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
Will 720P and 1080P dvdr discs play on a Non Blu Ray DVD Player?
By donfm in forum Newbie / General discussionsReplies: 21Last Post: 31st Mar 2008, 15:45 -
Looking for DVD player replacement - Good DVDR media support? (~£50)
By John_Jordan in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Mar 2008, 15:12 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14
