Help
I'm using Mainconcept to convert a .avi to DVD mpeg, and although I select DVD from the options menu, the end file size is 11Gb !!!
The annoying thing is that it tells me the end file size will be 4Gb (perfect) but it's a lie, as it turns out to be 11Gb.
I must be missing something really obvious, but I need your help please![]()
Cheers
handsy -
Click Details, Advanced, set it to CBR, adjust down to ~4500 bitrate. Encode. If needed, adjust lower.
Click Details, Advanced, Audio tab, set to 192kbps, or even 128, mpeg2, not PCM.Cheers, Jim
My DVDLab Guides
Blu-Ray to MKV with forced subtitles - Size of file not issue
By rajsharma714 in forum Blu-ray RippingReplies: 3Last Post: 16th Nov 2012, 21:25 -
quicktime pro will exporting to h.264 solve this huge file size issue?
By cybershot in forum Newbie / General discussionsReplies: 7Last Post: 10th Oct 2010, 21:43 -
XVID4PSP and target file size issue,
By bugsboney in forum Video ConversionReplies: 4Last Post: 11th Nov 2009, 17:24 -
File size (quality issue) transferring video
By subba in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Oct 2009, 05:53 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 17:53
