my friend has a dvdr that i borrowed
i try to burn with nero and it doesnt work
i try to rip with dvd shrink and that doesnt work either
wat do i do!?
-=Turbo=-
Please be more specific.
Are you saying:
1) You can not rip the files
or
2) You can rip them but not author them
or
3) You can rip & author but not get them to burn correctly
or
4) You can rip, author, & burn them but they will not play correctly
or
5) what??
In the meantime, try using DVD Decrypter or SmartRipper to rip the files to your hard drive. If it does not work, you may have some setup issues to deal with. -
Yup .... more info needed
When you say "doesn't work" what happens ? ... what error messages ?
What is the dvdr ..... data or movie ?
What media & burner are you using ?
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
Laptop DVDR/W Stopped Working Properly. Firmware Updates????
By Scooter_NJ in forum DVD & Blu-ray WritersReplies: 2Last Post: 8th Apr 2008, 04:32 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14
