Results 1 to 9 of 9
  1. i am trying to convert a downloaded xvid (avi) ac3 to dvd i have followed all the tutorials and i have all the nessecary tools however tempeg plus 2.5 will not allow me to inport avi file (before or after demux) FILE NOT SUPPORTED i have installed correct codecs and checked with gspot (i can also play title on pc no problem i have set higer priority in tmpeg to direct show multi media (as suggested in one of the posts here)
    TOOLS USED (or trying to use)
    gspot
    virtualdubmod
    bitrate calculator
    tmpeg plus 2.5
    tmpeg dvd author
    is there anything that i am missing
    much help apreciated ( i hope i have given enough information)
    file = width 608 x hieght 256
    AUDIO
    bitrate 448 kbps
    audio format = ac3 acm decompressor
    VIDEO
    frame rate = 23 frames per second
    data rate = 138 kbs
    video sample 24 bit
    video compression xvid
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    Install FFDSHOW and try again with TMPGEnc.
    Apr 2002
    The State of Frustration
    Also make sure the Direct Show priority is set to be the highest one.
    Hello.
  4. thanx for the tip teegee but its still the same even after installing ffdshow
    also i have set the direct show to the highest priority
  5. Member teegee420's Avatar
    Dec 2003
    Southern California
    Try frameserving with Virtualdub to TMPGENnc. Here's a guide: https://www.videohelp.com/forum/userguides/87270.php
    First install the handler by using "aux_setup.exe" in the Virtualdub prgram folder. Start using the guide at "Frameserve AVI with VirtualDub". You're done with the guide once (or if)TMPGEnc starts encoding.
    Apr 2002
    I think I couldn't see the forest for the trees. Try to do this with this program. It is the Virtual Dub MP2 AC3 version.
    Hello.
  7. Member teegee420's Avatar
    Dec 2003
    Southern California
    Ok Tommyknocker, I feel like a complete dumb-ass for asking this but what does "I think I couldn't see the forest for the trees" mean? I've never heard that expression before.
    Apr 2002
    Sorry, I'm showing my age. The saying refers to a reality: The forest is much more than trees. There are animals, streams, plants, rocks, insects, etc. To say this means you see so many symptons, you forget to look at the problem.
    Hello.
  9. Member teegee420's Avatar
    Dec 2003
    Southern California
    Wisdom is timeless, my friend. Thanks for the clarification. I'll have to remember that one.
