this only has happened twice, and has required me restart my computer to get the drive to open again. Any ideas? Yes this is 7 Hours 12 Minutes, and no progress past 6% has occured since its stopped.
(Image has been formatted to fit your screen and to fill the space alotted for this post. Unauthorized ..... blah blah blah blah....)
Any more info about your system? Motherboard make/model, OS, other system specs?
Just a suggestion, put all that info in your profile so you only need to post it once.
Out of curiosity, you aren't by chance running an nVidia nForce-based system are you? If so, uninstall the NV IDE drivers and use the MS ones. Burning problems with those drivers are well documented on this and other forums. I had lots of problems with them myself. -
Had this problem with a CD writer, my solution was to re-install the Nero Program. I don't know why it was stopping but re-installation stopped it, probably a corrupt file or something.
If it works, don't fix it. -
We need to know your system specs but I can say that I had the exact problem down to even having to restart to get the disc out of there. It was random and it would also do it with CD's while I was troubleshooting it. However, my Plextor CD-R/RW would burn all day long. It was as VinnySem said, my nForce drivers. I read it on here and "rolled back" to XP IDE drivers and all is well (after a half a dozen coasters). I can't say there's any negative impact on speed but I don't have any HDD's on these contollers, I have SATA drives in RAID. However, my Pioneer DVD-ROM stills rips like noboby's business so I would guess speed with XP drivers isn't an issue.
Let us know.
Long silence in ac3 is mysteriously shortened when I author
By Genaugmen in forum Authoring (DVD)Replies: 0Last Post: 20th Aug 2010, 16:47 -
x264 stops functioning mid way during encoding
By jones24 in forum Newbie / General discussionsReplies: 4Last Post: 19th Aug 2009, 04:03 -
Guide to fix Illegal Disc Error for NEC drive (possibly others)
By lucaschrist in forum DVD & Blu-ray WritersReplies: 10Last Post: 5th Apr 2008, 01:11 -
Imation not working in Nec 2500a
By anubis13 in forum MediaReplies: 3Last Post: 8th Oct 2007, 12:14 -
MAJOR probs w/ my NEC 2500A
By candlelight in forum DVD & Blu-ray WritersReplies: 25Last Post: 5th Sep 2007, 14:19
