I am trying to get about 4 hours of home video from mini DV's to DVD. I have about 50 GB of free disc space on my Hard Drive but after capturing the movie using VisualStudio 7, I did not have enought hard drive space to convert it so that it could be burned to disk (I was trying to use the highest resolution). I have VisualStudio 7 se basic, which does not burn to DVD. I also have sonic MyDVD and DVDshrink. I really am unsure on where to go from here without buying anything else. I would like good quality home video on DVD, it does not have to be super high quality. What do you guys recommend? Please keep in mind, I am new to digital movies and dvd writing. How many hours of home video can I expect to get on a DVD with good quality. Thanks for any help.
The way I see it, you have two choices. Either get another HDD (always a good idea), or capture 2 hrs and edit it down to 1 hr or less of the best material.
If you want to have good quality, expect to get 1 - 1:30 hrs on a DVDR. You should encode @ 7 - 8 mbps.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 10:41 -
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 18:27 -
True Newbie Here....be gentle. Mini dv questions.
By jsup in forum Newbie / General discussionsReplies: 7Last Post: 8th Nov 2009, 11:05 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 03:18 -
Hd Mini dv tapes via SD mini DV camcorder
By imptech3 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 03:11
